The leading platform for time series data
Join the millions of developers using InfluxDB to predict, respond, and adapt in real-time.
Get started with InfluxDB
Developers choose InfluxDB
More downloads, more open source users, and a stronger community than any other time series database in the world.
1B+
Downloads of InfluxDB via Docker
1M+
Open source instances live today
5B+
Downloads of InfluxData’s Telegraf
2,800+
Contributors
#1
Time series database
Source: DB Engines
Why InfluxDB
Manage high-volume, high-velocity data without sacrificing performance.
046-abstract shape-hl
Unmatched performance at scale
Manage millions of time series data points per second without limits or caps.
Run where
you need it
Run at any scale in any environment: in the cloud, on-prem, or at the edge.
Build with the
tools you love
Easily connect to your tech stack using data standards and 300+ integrations.
Engineered for the entire lifecycle of time series data at a lower TCO
High-Speed
Ingest
Real-Time Querying
with SQL
Best-in-Category Compression
Bulk Data Eviction
and Transfer
Code in the languages you love
No need to conform to a new language or technology. InfluxDB supports multiple programming and query languages, with client libraries and integrations to make things simple, all powered by a RESTful API.
See All Integrations
ReadWrite
c
c
c
c
                  import {InfluxDBClient} from '@influxdata/influxdb3-client'
import {tableFromArrays} from 'apache-arrow';
const database = process.env.INFLUX_DATABASE;
const token = process.env.INFLUX_TOKEN;
const host = "https://us-east-1-1.aws.cloud2.influxdata.com";
async function main() {
    const client = new InfluxDBClient({host, token})
    const query = `
    SELECT
      room,
      DATE_BIN(INTERVAL '1 day', time) AS _time,
      AVG(temp) AS temp,
      AVG(hum) AS hum,
      AVG(co) AS co
    FROM home
    WHERE time >= now() - INTERVAL '90 days'
    GROUP BY room, _time
    ORDER BY _time
    const result = await client.query(query, database)
    const data = {room: [], day: [], temp: []}
    for await (const row of result) {
      data.day.push(new Date(row._time).toISOString())
      data.room.push(row.room)
      data.temp.push(row.temp)
    console.table([...tableFromArrays(data)])
    client.close()
main()
c
c
c
c
c
c
c
c
c
c
c
c
c
c
500M+
Metrics collected daily
Mission-critical monitoring
Real-time data access for query
Read Case Study
Rajeev Tomer
Read Case Study
50%
lower total cost of ownership
100K
Read Case Study
“We decided, from a monitoring perspective, that we are... going with a best of breed setup. So, we put the best tools in place, like InfluxDB for metrics monitoring.”
Daniel Putz
DevOps Enablement
Read Case Study
Dylan Shorter
Read Case Study
45%
Less equipment downtime
10%
Reduced waste
Read Case Study
Ricardo Kissinger
Read Case Study
InfluxDB is a G2 Leader in Time Series
“InfluxDB is a strong database built specifically for time series data. It has made working with such data seamless and easy.”
— Verified G2 reviewer
Read reviews
G2 - Users Most Likely To Recommend
G2 - Leader Winter 2024
G2-MomentumLeader-Winter-2024
G2 Mid-Market Leader
G2 - Best Usability
G2 - Best Relationship
INDUSTRIES
Time series analytics for every industry
Today, InfluxDB deployments span multiple industries, with customers running at scale in any environment—public and private cloud, on-premises, and at the edge.
Manufacturing
Energy and Utilities
Consumer IoT
Industrial IoT
Manufacturing
Analyze production data streams in real-time to identify bottlenecks, prevent downtime, and power predictive maintenance for your industrial equipment.
Learn More
Manufacturing
Analyze production data streams in real-time to identify bottlenecks, prevent downtime and power predictive maintenance for your industrial equipment.
Learn More
Monitor, optimize, and manage renewable energy and traditional power systems to achieve smart grid balancing and optimization. Forecast and predict maintenance needs for your renewable energy sources such as wind turbines and solar farms.
Learn More
Analyze network performance and usage patterns in telecommunication infrastructure. Improve quality of service, optimize infrastructure resources, and reduce operational costs.
Learn More
Consumer IoT
Use real-time monitoring and analytics to optimize energy consumption and improve quality of life.
Learn More
Industrial IoT
Optimize operational processes with real-time insights from industrial equipment and sensors.
Learn More
Get real-time insights from satellites, networks, and every stage of the launch operation process. Reduce errors and accelerate time to market in this mission-critical space.
Learn More
