TL;DR InfluxDB Tech Tips - InfluxQL Query Solutions on the SELECT Clause, Field Keys, and Selector Function
Regan Kuchan
updated October 20, 2023
In this weekly post we recap the most interesting InfluxQL query and TICK-stack related issues, workarounds, how-tos and Q&A from GitHub, IRC and the InfluxDB Google Group that you might have missed in the last week or so.
Regular expressions in the SELECT clause
Q: I’m specifying multiple specific field keys in the SELECT clause - is there any way to do this without having to list them all out?
My current query:
SELECT user_name,user_id,user_email[,...] FROM all_the_data
A: Starting with version 1.1, the SELECT clause supports regular expressions. Something like the following query might work, depending on your data:
SELECT /user/ FROM all_the_data
Check out the Data Exploration page or this InfluxQL short for more on the SELECT clause.
Workaround for dropping individual field keys
Q: Is there any way to drop specific field keys from a measurement? I see that there’s DROP SERIES, DELETE, and DROP MEASUREMENT , but I can’t find anything about dropping field keys.
A: Currently, InfluxQL doesn’t have a query for dropping specific field keys from a measurement. As a workaround, you can write the field keys that you want to keep to a different measurement, drop the original measurement, and then write the saved field keys back to the original measurement.
Raw data:
> SELECT * FROM "holidays"
time TOREMOVE happiness_index self_worth user_id <--- this is a tag
2016-11-30T20:05:48Z 0 20 10 1
2016-11-30T20:06:30Z 0 12 0.9 1
2016-11-30T20:07:13Z 0 13 4 1
Write the necessary field keys to a different measurement (holidays_copy):
> SELECT "happiness_index","self_worth" INTO "holidays_copy" FROM "holidays" GROUP BY *
time written
1970-01-01T00:00:00Z 3
> SELECT * FROM "holidays_copy"
time happiness_index self_worth user_id
2016-11-30T20:05:48Z 20 10 1
2016-11-30T20:06:30Z 12 0.9 1
2016-11-30T20:07:13Z 13 4 1
Drop the original measurement:
> DROP MEASUREMENT "holidays"
Write the saved field keys back to the original measurement:
> SELECT * INTO "holidays" FROM "holidays_copy" GROUP BY *
time written
Be sure to include GROUP BY * in your INTO queries to preserve any tags as tags.
Selector functions in depth
Q: I’m having trouble understanding how a selector function, like LAST(), behaves when I run the two queries below. Will query 1 return the last value of fungi_index and the value of tree_age at that time? And for query 2, are the LAST calculations independent and what timestamp would that query return if the last values of fungi_index and tree_age occur at different times?
Query 1:
SELECT LAST("fungi_index"),"tree_age" FROM "forest"
Query 2:
SELECT LAST("fungi_index"),LAST("tree_age") FROM "forest"
A: You’re right about query 1; it does return the last value of fungi_index and the value of tree_age at that time. You can see that in the column headers of the returned data. The header for last value of fungi_index is last and the header for the value of tree_age is tree_age.
Query 2 returns a single point which includes the last value of fungi_index and the last value of tree_age, independent of the last value of fungi_index. The timestamp for that point is 1970-01-01T00:00:00Z (InfluxDB’s null timestamp equivalent) because InfluxDB can’t return more than one timestamp for a single point.
Raw data:
> SELECT * FROM forest
time fungi_index tree_age
2016-11-30T21:43:00Z 12 85
2016-11-30T21:44:00Z 34 172
2016-11-30T21:45:00Z 8
Query 1:
time last tree_age
Query 2:
time last last_1
1970-01-01T00:00:00Z 34 8
For more InfluxDB tips, see our Frequently Asked Questions page and feel free to post your questions in the InfluxDB users group!
What's next
- Downloads for the TICK-stack are live on our "downloads" page
- Deploy on Your Servers: Want to run InfluxDB clusters on your servers? Try a FREE 14-day trial of InfluxDB Enterprise featuring an intuitive UI for deploying, monitoring and rebalancing clusters, plus managing backups and restores.
- Tell Your Story: Over 100 companies have shared their story on how InfluxDB is helping them succeed. Submit your testimonial and get a limited edition hoodie as a thank you.
