TL;DR InfluxDB Tech Tips - Configuration & Excluding Tags from Plugins with Telegraf 0.13
Regan Kuchan /
In this post we recap the week’s most interesting InfluxDB, Telegraf 0.13 and TICK-stack related issues, workarounds, how-tos and Q&A from GitHub, IRC and the InfluxDB Google Group that you might have missed.
Recover a lost admin user password
Q: What should I do if I forget the admin user password?
A: You’ll need to access InfluxDB to change the admin password or create a new admin user. This requires access to the configuration file:
- Disable http authentication in the
[http]section of the configuration file:
[http]
enabled = true
bind-address = ":8086"
auth-enabled = false #?
- Restart InfluxDB:
sudo service influxdb restart
- Connect to the CLI (no need for credentials now!):
influx
4. Reset the password or create a new admin user:
> SET PASSWORD FOR <username> = '<password>'
or
> CREATE USER <username> WITH PASSWORD '<password>' WITH ALL PRIVILEGES
- Enable http authentication in the
[http]
enabled = true
auth-enabled = true #?
- Restart InfluxDB, and you’re good to go!
Allow a non-admin user to USE DATABASE in the CLI
Q: I created a user and gave them full access to a database. However, that user cannot USE that database in the CLI:
> USE special_db
ERR: error authorizing query: <username> not authorized to execute statement 'SHOW DATABASES', requires admin privilege
A: The CLI issues a SHOW DATABASES command as part of the USE statement, and SHOW DATABASES is not authorized for non-admin users.
The workaround is for the user to explicitly connect to the right database when launching the CLI, for instance:
> influx -username 'username' -password 'password' -database 'special_db'
All operations for the duration of that CLI session will go against the special_db database.
Exclude tags from Telegraf 0.13 plugins
Q: Is it possible to prevent a plugin from emitting a tag?
A: The arguments taginclude and tagexclude are now in Master and will be available in Telegraf 0.13. See the Telegraf configuration doc for more details.
What's next?
- Download and get started with InfluxDB!
- Attend one of our FREE virtual training seminars.
- Got a question and need an immediate answer from the InfluxData Support team? Support subscriptions with unlimited incidents start at just $399 a month. Check out all the support options here.
