Running InfluxDB 2.0 and Telegraf Using Docker
Anais Dotis-Georgiou
updated October 24, 2023
Getting Started
This post was originally published in January 2021, and in an effort to keep it relevant, we updated it in December 2022.
The code associated with this blog can be found in this repo.
While the Docker buzz has faded a bit, replaced by new words like “Kubernetes” and “Serverless”, there is no arguing that Docker is the default toolchain for developers looking to get started with Linux containers, as it is fairly ubiquitous and tightly integrated with a variety of platforms.
Linux containers are an abstraction built from several pieces of underlying Linux functionality like namespaces and cgroups, which together provide a type of OS-level virtualization; to your applications, it seems like each one of them is running alone on their own copy of the OS. As a result, Docker provides a variety of benefits over running software directly on a host machine; it isolates your applications from the rest of your system, and each other, and makes it easier to deploy applications across a variety of operating systems. In general, it just keeps things clean, tidy and well-partitioned.
If you’re interested in learning more about containers, I highly recommend “What even is a container” by Julia Evans.
Personally, I run Docker on the desktop and deploy as many of my applications there as possible; not only does it keep cruft off my host — I often need to bring up a new copy of the stack to test a particular issue, develop a new feature, or present a demo, which Docker makes exceptionally easy.
Linux containers, and Docker, are great tools that should be part of every developer’s arsenal. So how can we use them to run InfluxDB 2.x?
Table of contents
The Docker pieces
You’ll need Docker installed on your local machine. The Docker website has documentation for installation on macOS and Windows. There are also instructions for several varieties of Linux in the Docker CE installation documentation.
Since Docker is an implementation of Linux containers, it requires a Linux OS to run. When you install Docker for Windows or macOS, it will set up and manage a virtual machine with the Linux kernel which will run all of your containers. On macOS, the virtual machine is set up by using HyperKit, while on Windows virtualization is provided by Hyper-V. Unfortunately, Hyper-V is only supported on Windows 10 Enterprise, Professional, and Education; users running Windows Home will need to use the legacy Docker Toolbox.
To run InfluxDB 2.0 and Telegraf in containers, you’ll need:
- The official images on the Docker hub for Telegraf.
- The image for InfluxDB 2.0.
Running Docker containers
There are a few ways to interact with Docker and manage your containers. The first is using the docker executable to issue commands like docker run and docker stop.
If you followed the installation instructions for Docker through to the end, you should have already launched the hello-world container using the following command:
$ docker run hello-world
When running more complex software, we often have to provide additional arguments to the docker run command to configure the container environment. This can include exposing ports in the container to the Docker host, or mounting volumes for persistent storage.
Docker networks
First, though, we’re going to set up a new Docker network. Docker comes with a built-in network that all containers are attached to by default, but creating a new network for our InfluxDB 2.0-r.c and Telegraf deployment will keep them isolated while allowing them to communicate with one another. Isolation is good for a number of things, but this can be especially helpful for bringing up multiple instances of the stack for testing or development. You can read more about the differences between the default network and a user-defined one in the documentation.
We’ll create a new network using the following command:
$ docker network create --driver bridge influxdb-telegraf-net
which creates a new network using the bridge driver, and gives it the name influxdb-telegraf-net.
When we execute our docker run command to start the container, we’ll add the following argument to connect it to our newly created network:
--network influxdb-telegraf-net
We’ll also want to expose a port from the container to the Docker host, so we can communicate with the applications in our containers from the outside world. We’ll use InfluxDB v2 as an example. The database communicates over port 8086 by default. Use publish flag, --publish or -p, and add the following two lines to our docker run command to expose the port:
-p 8086:8086
Persistent storage
Next up, we’ll need to make some decisions about where we want our configuration files to live, and where we’re going to store container data for those containers that need it.
Continuing to build out our InfluxDB run command, the database expects that it will have access to one file location on Linux, /root/.influxdb2, where it stores its data and configs. It’s possible to customize these locations, but for us the defaults are good enough.
We’re going to mount local folders into those locations in the container by adding the volumes flag, --volume or -v, to docker run. If you wanted, you could let Docker manage a volume for you, but binding a folder on the local machine ensures that we’ll be able to access the data from our host OS.
The bind points on the Docker host will vary based on the machine you’re running on. For the sake of example, we’ll pretend we have a folder in the user’s home directory called influxdb, and two subfolders within that are called data and config. We’ll provide the following arguments to mount those two folders inside the container:
-v /tmp/testdata/influx:/root/.influxdb2
Putting it all together: running InfluxDB in a container over a network
We’re just about ready to fire up our first container. We just need to add a few more things to our docker run command. We’re going to use the -d flag to start the container in “detached” mode, which runs it in the background, and we’re going to give it a name with the --name parameter. Finally, we’ll run the most recent version of the influxdb container.
docker run -d --name=influxdb \
-p 8086:8086 \
-v /tmp/testdata/influx:/root/.influxdb2 \
--net=influxdb-telegraf-net \
influxdb:2.0
After you run the command successfully, you should see a generated Container ID like:
8d868d437d5444c4ce0db04f208939843113db651a3729ce3c924bd11df19d38
Next we’ll run a Telegraf container in a similar fashion. But before we do, we need to configure our InfluxDB instance.
Configuring your InfluxDB 2.0 instance
The easiest way to configure your InfluxDB 2.0-r.c. instance is through the UI. Visit http://localhost:8086 to complete the setup and gather the necessary authorization credentials. To write data to InfluxDB with Telegraf, you’ll need to:
You can also complete the setup with the InfluxDB CLI. To launch the CLI within the container itself, you need the docker exec command. It enables you to run an interactive session. Provide the -io and -t arguments to create an interactive session and allocate a pseudo TTY, respectively. The influx setup command allows you to set up your InfluxDB instance interactively with the CLI.
Use the following command to execute the influx CLI within our influxdb container:
$ docker exec -it influxdb influx setup
Managing your Telegraf configuration
After collecting all the credentials above, we can configure the output portion of our Telegraf configuration. It looks like this:
[[outputs.influxdb_v2]]
## urls exp: http://127.0.0.1:8086
urls = ["http://influxdb:8086"]
## Token for authentication.
token = "$DOCKER_INFLUXDB_INIT_ADMIN_TOKEN"
organization = "$DOCKER_INFLUXDB_INIT_ORG"
bucket = "$DOCKER_INFLUXDB_INIT_BUCKET"
Also note that we must change the url from localhost to influxdb, the name of our container that’s running InfluxDB 2.0-r.c. This change will allow our telegraf container to communicate with the influxdb container over the net.
Mounting Telegraf configuration files
Starting to build out our telegraf run command, the agent expects that it will have access to the file locations on Linux, /etc/telegraf/telegraf.conf, where it stores its telegraf config. It’s possible to customize these locations, but for us the defaults are good enough.
The bind points on the Docker host will vary based on the machine you’re running on. For the sake of example, we’ll pretend we have a Telegraf configuration in the lizzo user’s home directory. We’ll provide the following argument to mount this configuration inside the container running Telegraf:
-v /mytelegrafconfigsdir/telegraf.conf:/var/lib/influxdb
Putting It All Together: Adding A Container Running Telegraf To Our Net
We’re just about ready to fire up our first container. We just need to add a few more things to our docker run command. We’re going to use the -d flag to start the container in “detached” mode, which runs it in the background, and we’re going to give it a name with the –name parameter. Finally, we’ll run the most recent version of the influxdb container.
docker run -d --name=telegraf \
-v /mytelegrafconfigsdir/telegraf.conf:/var/lib/influxdb \
telegraf
Go ahead and run that at the command line. If it succeeds, it should return a unique hash that identifies the running container like before.
Operating containers
Now that we have a running container, let’s talk about some additional operational details. The first thing we generally need to check is whether our containers are running. For this, we can use the docker ps command:
$ docker ps
CONTAINER ID IMAGE COMMAND CREATED STATUS PORTS NAMES
e0be3cb0de4b telegraf "/entrypoint.sh tele…" 10 minutes ago Up 10 minutes 8092/udp, 8125/udp, 8094/tcp telegraf
8d868d437d54 quay.io/influxdb/influxdb:2.0.0-rc "/entrypoint.sh infl…" 12 minutes ago Up 12 minutes 0.0.0.0:8086->8086/tcp influxdb
Great! Our containers are up and running. But maybe they’re not behaving like we expect? We might want to dig in and take a look at the logs. We can get those using the docker logs command and providing the name of the container. We’ll also add a -f argument. This follow command will continue streaming the new output from the container’s STDOUT and STDERR. Receiving all the Telegraf logs can be very useful during debugging. Additionally, you might benefit from setting debug=true in the agent portion of your Telegraf config if you are having trouble writing data to InfluxDB. The command looks like this:
$ docker logs telegraf -f
Docker Compose
Docker Compose is “a tool for defining multi-container Docker applications”. It lets us bring up multiple containers and connect them together automatically, and we can use it to help us roll out and manage the complete TICK Stack more easily. We’ll start by defining the various services that are part of the TICK Stack within a docker-compose.yml file, then deploy those services using the Compose command line tool.
Below is an example docker-compose.yml (using Compose file format version 3) which defines three services, influxdb, influxdb_cli, and telegraf:
version: '3'
services:
influxdb:
image: influxdb:2.6-alpine
env_file:
- influxv2.env
volumes:
# Mount for influxdb data directory and configuration
- influxdbv2:/var/lib/influxdb2:rw
ports:
- "8086:8086"
telegraf:
image: telegraf:1.25-alpine
depends_on:
- influxdb
volumes:
# Mount for telegraf config
- ./telegraf/mytelegraf.conf:/etc/telegraf/telegraf.conf:ro
env_file:
- influxv2.env
volumes:
influxdbv2:
To deploy these services, run docker-compose up -d (like docker run, the -d argument starts the containers in headless “detached” mode). docker-compose uses the directory where it is executed to name the various components it manages, so putting your docker-compose.yml file into a well-named directory is a good idea. For this example, we’ll place our docker-compose.yml file in a directory called influxv2.
Running docker-compose up -d will do a number of things: first, it will create a new Docker network named influxv2_default, and then it will bring up a container for each of the services we defined, naming them influxv2_influxdb_1,influxv2_influxdb_cli_1, and influxv2_telegraf_1 respectively.
$ docker-compose up -d
[+] Running 3/3
⠿ Network influxdbv2_telegraf_docker_default Created 0.0s
⠿ Container influxdbv2_telegraf_docker-influxdb-1 Started 0.4s
⠿ Container influxdbv2_telegraf_docker-telegraf-1 Started 0.7s
$ docker ps -a
e6d60ddc155e telegraf:1.25-alpine "/entrypoint.sh tele…" 39 seconds ago Up 37 seconds 8092/udp, 8125/udp, 8094/tcp influxdbv2_telegraf_docker-telegraf-1
086e06ca4416 influxdb:2.6-alpine "/entrypoint.sh infl…" 39 seconds ago Up 38 seconds 0.0.0.0:8086->8086/tcp influxdbv2_telegraf_docker-influxdb-1
influxdb
You should be able to navigate to the InfluxDB UI by visiting http://localhost:8086 and login by passing in your username and password (myu as defined by the influx setup command in the entrypoint definition in the influxdb_cli service. Specifically, you will use myusername and passwordpasswordpassword for the username and password, respectively. Please keep in mind that your password must be a minimum of 8 characters.
Finally, ensure that your InfluxDB setup parameters match your Telegraf configuration parameters. For example, the output portion of mytelegraf.conf would look like this:
# Output Configuration for telegraf agent
insecure_skip_verify = true
Wrapping Up
Don’t forget to clean up any containers you created while following along with this blog post! Use docker stop and docker rm commands to do so. Another thing to keep track of while using Docker is the container images themselve. A Docker image isn’t automatically deleted, and so over time as you upgrade the versions of the software you’re using, old containers can accumulate and start eating up disk space. There are some scripts out there which will manage this for you, but for the most part just being aware of the potential issue and cleaning up manually every now and then will be good enough.
I hope you find this blog useful. If you have any questions or product feedback, please post them on the community site, Slack channel, or tweet us @InfluxDB. Thanks!
