InfluxDB Week in Review - September 21, 2015
Jimmy Guerrero /
Blogs
- Using telegraf to send metrics to InfluxDB and Apache Kafka
- InfluxDB 0.9.4 released with top function, order by time desc and more
Videos
New and Updated Documentation
- Frequently Encountered Issues (Troubleshooting Tips)
- Writing data to InfluxDB with the HTTP API
- Understanding time-series databases for the SQL DBA
Events
Watch this space! InfluxDB will be presenting at Meetups in San Francisco, Denver and Chicago very soon. Dates will be announced shortly.
TL;DR Tech Tips
Getting an HTTP URL to return JSON data without using curl
Q: Is there a way to get a URL to return JSON data without using the curl command?
A: Yes, just make sure to URL encode the string so it’s a valid hyperlink. For example:
http://localhost:8086/query?db=dbname&q=SHOW%20MEASUREMENTS
Aggregations over specific time periods
Q: I need to do aggregations over events grouped by specific time periods (weekdays, months and hours) to get the most popular dayweek for an event. How do I do this?
A: Custom grouping periods are currently not supported, so a good workaround for now is to add new tags to the data model such as weekday (with values 1-7), month (1-12) and dayhour (0-23). This allows you to do GROUP BYs over these tags.
Shutting down InfluxDB gracefully
Q: How do I shutdown InfluxDB gracefully?
A: If installed as a service, execute:
service influxdb stop
otherwise send SIGTERM to the influxd
process.
Get your InfluxDB hoodie while they last!
Does your company have a cool app or product that uses InfluxDB in production? We’d love to feature it on influxdb.com and give you a shout out on social media. As a “thank you” gift, we’ll send you an InfluxDB hoodie and a pack of stickers. Just fill out this simple form and we’ll let you know when your entry is live and the hoodie is in the mail. Drop us a line at [email protected] if you have any questions. Thanks for the support!
