Import JSON Data into InfluxDB using the Python, Go, and JavaScript Client Libraries
Josh Powers /
Devices, developers, applications, and services produce and utilize enormous amounts of JSON data every day. A portion of this data consists of time-stamped events or metrics that are a perfect match for storing and analyzing in InfluxDB. To help developers build the applications of the future, InfluxDB provides several ways to get JSON data into InfluxDB easily.
This blog post demonstrates how to take JSON data, translate it into line protocol, and send it to InfluxDB using the InfluxDB Client libraries.
What are JSON and line protocol?
JSON, or JavaScript Object Notation, is a text-based data format made up of attribute-value pairs and arrays and is readable by humans and machines. The format grew out of the need for stateless server-to-browser communication. Commonly associated with REST services, like APIs found on the web, today it is widely used in many scenarios to send and receive data.
Below is an example of a fictional JSON data point from a weather sensor containing a variety of sensor readings:
"location": {
"lat": "43.56704 N",
"lon": "116.24053 W",
"elev": 2822
"name": "KBOI",
"sensors": {
"temperature": 48,
"dew_point": 34,
"humidity": 61,
"wind": 9,
"direction": "NW",
"pressure": 30.23
"updated": "25 Oct 12:05 PM MDT"
To get this data into InfluxDB, the following tools show how to translate these rows into line protocol. Line protocol consists of the following items:
- Measurement name: the name data to store and later query
- Fields: The actual data that will be queried
- Tags: optional string fields that are used to index and help filter data
- Timestamp: optional; if not provided, the current timestamp is used
Using the JSON example above, the goal state is to translate the data into the following line format:
weather,station=KBOI dew_point=34i,direction="NW",humidity=61i,pressure=30.23,temperature=48i,wind=9i 1666721100000000000
Client Libraries
The InfluxDB Client libraries are language-specific packages that integrate with the InfluxDB v2 API. These libraries give developers a powerful method of sending, querying, and managing InfluxDB. Check out this TL;DR for an excellent overview of the client libraries. The libraries are available in many languages, including Python, JavaScript, Go, C#, Java, and others.
The client libraries provide developers with the tools they need to quickly send read and transformed data into InfluxDB. This way developers can work in the specific language they are most comfortable with or with what the problem space requires. And at the same time have a direct method to inject data into InfluxDB.
The rest of this post demonstrates how to read the JSON data from the example above using the Python, Go, and JavaScript client libraries.
Python
The Python language and ecosystem have demonstrated a phenomenal way to parse and clean data. Users build Python-based tooling to manipulate data in many different use cases, from IoT devices to enterprise applications. The simple syntax and powerful libraries make it a great first option for getting data into InfluxDB. We have a video series introducing the Python client library here.
The following example demonstrates reading the weather JSON data as a file into a Python dictionary, generating a data point, and sending that data point to InfluxDB:
#!/usr/bin/env python3
"""Example to read JSON data and send to InfluxDB."""
from dateutil import parser
import json
from influxdb_client import InfluxDBClient, Point, WriteOptions
from influxdb_client.client.write_api import SYNCHRONOUS
point = Point("weather")
with open("../data/weather.json", "r") as json_file:
data = json.load(json_file)
point.tag("station", data["name"])
point.time(parser.parse(data["updated"]))
for key, value in data["sensors"].items():
point.field(key, value)
with InfluxDBClient.from_config_file("config.toml") as client:
with client.write_api(write_options=SYNCHRONOUS) as writer:
try:
writer.write(bucket="my-bucket", record=[point])
except InfluxDBError as e:
print(e)
This example uses the Point
helper. This helper allows developers to quickly and easily generate data in line protocol with the provided helper functions. This creates the weather data point, then sets a single tag based on the station name, uses the data’s timestamp as the timestamp, and then takes all the sensor readings and makes them fields.
Using the Point helper is one of many ways to write data. Developers could have data to send in the form of a Python Dictionary that specifies the metric name, tags, fields, and timestamp or generates a simple string. For more examples of these, check out the Deep Dive into the WriteAPI blog post.
Go
Go established itself as a high-performance, readable, and efficient language. While it gained initial popularity from server-side, backend development, Go is used across CLI applications, IoT devices, and scientific applications.
In this example, a Weather
struct is created to unmarshal the Weather station data easily. Then, use the NewPoint
helper to create the data point and, finally, send it to InfluxDB.
package main
import (
"encoding/json"
"os"
"time"
influxdb2 "github.com/influxdata/influxdb-client-go/v2"
type Weather struct {
Name string `json:"name"`
Timestamp string `json:"updated"`
Location Location `json:"location"`
Sensors map[string]any `json:"sensors"`
type Location struct {
Lat string `json:"lat"`
Lon string `json:"lon"`
Elev int `json:"elev"`
type Sensor struct {
Temperature int `json:"temperature"`
DewPoint int `json:"dew_point"`
Humidity int `json:"humidity"`
Wind int `json:"wind"`
Direction string `json:"direction"`
Pressure float64 `json:"pressure"`
func main() {
bytes, err := os.ReadFile("../../data/weather.json")
if err != nil {
panic(err)
data := Weather{}
if err := json.Unmarshal(bytes, &data); err != nil {
panic(err)
timestamp, err := time.Parse(
"2006 02 Jan 03:04 PM -0700",
data.Timestamp
if err != nil {
panic(err)
p := influxdb2.NewPoint(
"weather",
map[string]string{
"station": data.Name,
data.Sensors,
timestamp,
client := influxdb2.NewClient("http://localhost:8086/", "my-token")
writer := client.WriteAPI("my-org", "my-bucket")
writer.WritePoint(p)
client.Close()
This example reads the JSON file but then unmarshals the data and parses the timestamp. This occurs using the internal parse method along with the format using the Go standard time to explain the format.
The NewPoint
helper, in this case, allows the user to quickly and easily specify the various parts of line protocol sent to InfluxDB with the WritePoint()
function. Developers could also write a string of line protocol using the WriteRecord()
function.
JavaScript/Node.js
JavaScript is a core technology of the web. With the release of Node.js, users can run JavaScript in places other than a browser. As a result, the use of JavaScript grew significantly from primarily websites to include server-side, mobile, and other user applications.
This example is a Node.js script that, similar to the other examples, reads in a file, creates a Point, and sends it to InfluxDB. You could adapt this to meet many other scenarios:
#!/usr/bin/env node
import {readFileSync} from 'fs'
import {InfluxDB, Point, HttpError} from '@influxdata/influxdb-client'
import {url, token, org, bucket} from './env.mjs'
const data = JSON.parse(readFileSync('../data/weather.json', 'utf8'))
const point = new Point('weather')
.tag('station', data.name)
.intField('temperature', data.sensors.temperature)
.intField('dew_point', data.sensors.dew_point)
.intField('humidity', data.sensors.humidity)
.intField('wind', data.sensors.wind)
.stringField('direction', data.sensors.direction)
.floatField('pressure', data.sensors.pressure)
.timestamp(new Date(data.updated))
const writeApi = new InfluxDB({url, token}).getWriteApi(org, bucket, 'ns')
writeApi.writePoint(point)
try {
await writeApi.close()
} catch (e) {
if (e instanceof HttpError) {
console.error(e.statusCode)
console.error(e.statusMessage)
Like Python, JavaScript uses the Point
helper to generate a valid line protocol data point. The user specifies the various tags, fields, and their respective data types, and the timestamp before writing the data to InfluxDB.
Get your JSON data into InfluxDB today
This post shows how quick, easy, and flexible the InfluxDB client libraries are. While the above only demonstrates JSON data, it starts to illustrate the great power developers have when sending data to InfluxDB. Combined with the other APIs, developers have even more options and potential.
Consider where you might be able to use InfluxDB and the client libraries, and give them a shot today!
