How to Output Data from Flux to MQTT Natively
David G. Simmons /
Use Cases, Product
Aug 16, 2019
Writing data from InfluxDB to MQTT using Flux
I started using the Open Source (OSS) version of InfluxDB v2.0 very early on in the Alpha releases. Even in the early releases, I was very enamored with the way things were shaping up. But as you know, I do a lot of IoT builds, and use InfluxDB for all of it, so there were a few things I needed it to do that it just didn’t, yet.
One of the things I have all my IoT Demos do is to write out alerts to an MQTT broker. I have other IoT Devices that read from that broker, and take actions based on what messages they receive. But InfluxDB 2.0 Alpha had no real output capabilities.
Note: There is an alerting framework that is coming to InfluxDB 2.0 very soon, but a) it wasn’t available then and b) I needed it now.
What to do? Well, Flux is an extensible language, so I decided to extend the language to write to MQTT. First, it’s important to note that Flux has 2 language constructs for reading and writing data: from()
and to()
. If you’ve written any Flux at all, you’ll recognize the from()
syntax as being how you get data back from InfluxDB. The to()
business is a bit harder. Built into the language is the ability to write back to InfluxDB, using the to()
syntax. I also found a to()
extension for http that allows you to write the results of your Flux query out to an http end-point. At least I now had a starting place!
Adding MQTT to Flux
I began poking around in the Flux code to see how the http to()
method was implemented and quickly saw that it would be almost trivial to use this same framework for MQTT, so I copied all the code fro the http to()
output and began working to move it over to MQTT. As with all of these things, it was a little less ‘trivial’ than I at first thought, but after a few weeks of on-again off-again work, I had a working output to MQTT from Flux!
First, I had to define what options the MQTT output would need, and I settled on a sort of default minimum set of options:
golang
type ToMQTTOpSpec struct {
Broker string `json:"broker"`
Name string `json:"name"`
Topic string `json:"topic"`
Message string `json:"message"`
ClientID string `json:"clientid"`
Username string `json:"username"`
Password string `json:"password"`
QoS int `json:"qos"`
NameColumn string `json:"nameColumn"` // either name or name_column must be set, if none is set try to use the "_measurement" column.
Timeout time.Duration `json:"timeout"` // default to something reasonable if zero
NoKeepAlive bool `json:"noKeepAlive"`
TimeColumn string `json:"timeColumn"`
TagColumns []string `json:"tagColumns"`
ValueColumns []string `json:"valueColumns"`
Of course, not all of those are required, but I’ll go through the ones that are.
First, of course, you need to define a Broker. This is the URL of the MQTT broker that you want to use. In your URL your broker should be identified as either tcp
, ws
or tls
so tcp://mqtt.mybroker.com:1883
would be what it’s looking for. Most of the rest are, by and large, optional to a degree. If you supply a Username
then you must also supply a password. You can’t have one without the other! Also, if you don’t supply a Topic
then one will be created for you by stringing together all of the tags returned from your query. I’d advise giving a topic, as a topic of /tag1/tag_2/tag_3/...
would be less than ideal in a lot of situations.
How to use this new thing?
I’m glad you asked! First, it’s not actually part of Flux just yet. I have submitted a PR, it has been accepted, but (as of this writing) has not been merged. If you want to build your own version of Flux in order to get your hands on this now then you’ll need to pull the branch and build from source. See the MQTT PR and go from there.
Once you’ve done that, the Flux code to start writing to an MQTT broker is actually trivial! You’ll want to create a Task in the InfluxDB 2.0 UI, and then you can paste in the following code:
import "mqtt"
from(bucket: "telegraf")
|> range(start: -task.every)
|> filter(fn: (r) =>
(r._measurement == "cpu"))
|> filter(fn: (r) =>
(r._field == "usage_system"))
|> filter(fn: (r) =>
(r.cpu == "cpu-total"))
|> last()
|> mqtt.to(
broker: "tcp://davidgs.com:8883",
topic: "cpu",
clientid: "cpu-flux",
valueColumns: ["_value"],
tagColumns: ["cpu", "host"],
This will write the last CPU usage_system
value to your MQTT broker. Using the UI, you can decide how frequently you want this data written.
A few things to note
It’s important to realize that Flux returns all of its data from queries as tables. The reason the above Task uses the last()
function is to limit the returned value to a table with exactly one row. The MQTT to()
function will write the whole table to the broker, as line-protocol. If your query returns a very large table, be prepared for your MQTT broker to get a very large table as the message payload.
In addition, if your query returns multiple tables, the MQTT to()
function will write one message per table with each message containing an entire table. If this is not the behavior you want, you should think about how to craft your query such that it returns a single (preferably small) table as the results.
You may also have noticed an optional field Message
above. If what you’d like is to send a pre-defined message instead of a table of results, you can define the message
parameter in your call to to()
and that message will be sent.
So far, I’ve been using this for about 2 months with fantastic results! I’m able to control some IoT devices based on the readings from other IoT devices and it works great!
Update: The PR for this has now been merged into the master branch so it should be showing up in a release of Flux soon!
