InfluxDB Edge Data Replication
Process data at the edge and automatically replicate it to the cloud in a durable, reliable way.
Why use InfluxDB Edge Data Replication?
Running a full-fledged instance of InfluxDB at the edge means users working at the edge can do more locally. It allows them to collect, process, transform, and analyze high-precision data for local use, in real time. Replicating that data to the cloud enables users to aggregate and store data for long-term management and analysis, and to satisfy regulations.
Automatic
No need to write complex code or manage separate systems. Edge Data Replication starts with a simple configuration and then sends the data you specify to the cloud automatically.
Durable
Edge Data Replication utilizes a durable on-disk queuing system that continues to function through connectivity errors or outages.
Flexible
Use the same data, or a subset of it, at edge and in the cloud for different purposes. Edge Data Replication ensures the right data gets where it needs to go.
Key capabilities
Queue-based service
InfluxDB Edge Data Replication is a reliable, queue-backed service that lets you replicate data between InfluxDB at the edge and another InfluxDB instance, whether in the cloud or at the edge. The replication stream uses an internal, durable queue to buffer any data designated for replication.
Data flexibility
Use your data where you want it, when you want it. Save on data transfer and storage costs by sending only the data you need to the cloud. Whether you want to send all your raw data, downsample it, or clean it, you can do more at the edge before sending it to an InfluxDB Cloud instance.
Local insight
Leverage full InfluxDB capabilities – collection, storage, analysis, alerts – for any edge source. Ingest data from anywhere with powerful tools, including Telegraf, client libraries, and APIs. Manage high-volume data workloads near its source at the edge, reducing latency and eliminating connectivity-related issues.
Key capabilities
Queue-based service
InfluxDB Edge Data Replication is a reliable, queue-backed service that lets you replicate data between InfluxDB at the edge and another InfluxDB instance, whether in the Cloud or at the edge. The replication stream uses an internal, durable queue to buffer any data designated for replication.
Data flexibility
Local insight
Leverage full InfluxDB capabilities – collection, storage, analysis, alerts – for any edge source. Ingest data from anywhere with powerful tools, including Telegraf, client libraries, and APIs. Manage high volume data workloads near its source at the edge, reducing latency and eliminating connectivity-related issues.
InfluxDB Edge Replication overview
